주요 콘텐츠로 건너뛰기
조이콘 컨트롤러와 약간 더 작은 스크린이 통합된 보다 합리적인 가격의 순수 핸드헬드 버전의 Nintendo Switch의 게임 콘솔입니다. 2019년 9월 20일 출시.
175 질문 전체 보기
Does the console still work with a desoldered wifi ic
As I want to give my switch lite to my little brother I was wondering if the wifi ic on the mainboard can be desoldered without causing any functionality issues ( other than the lack of wifi of course) as he is is not allowed to have any “wifi compatible” devices?
Btw please no suggestions for the Nintendo parental control app or something like this, been there done that:)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I haven’t come across any device where an uninstalled Wi-Fi chip would stop it functioning. However if too much heat is applied while removing it you could end up with a brain dead Nintendo.
 Make sure you clean the pads after removal in case of some bridging and make sure you don’t nudge any of the other components around the chip.
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
thanks, I was just curious since the wifi ic of the original switch seemed to cause the system to freeze at the boot logo, just like the switch checks the availability of each component on the board before it can boot.
*non properly soldered wifi ic
@jake95 I have also seen this. I have just replaced the Wi-Fi chip if I couldn’t find anything else that stood out. I just put it down to a faulty chip which would cause it not to boot. I haven’t tried to boot one without it but like I said all the other devices I have worked on will boot without one.
You can purchase pre balled Wi-Fi IC’s for around $10 so if it doesn’t boot you can just put the pre-balled one on.
Hey @imicrosoldering!
I just ran across this thread while trying to solve an issue with a switch that will not power on after a wifi IC replacement.
Could you elaborate on what you mean by a "brain dead" Nintendo and how excessive heat could cause this?
댓글 달기
귀하의 답변을 추가하세요
jake95 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 18
전체 시간: 590
