주요 콘텐츠로 건너뛰기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 Touch Bar가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
260 질문 전체 보기
Why is my replaced battery only charging once it has been drained?
I replaced my battery a second time after the first stopped charging at all. The second battery only seems to charge once it has run out completely and not while plugged in and being used - I have attached a coconutBattery screenshot. Any ideas?
I have updated to Monterey to see if it helps. Here is the current info:
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Thank you. I guess there’s not much I can do about that. ☹️
댓글 달기
답변 1개
선택된 답변
You have a threshold issue within the charging control logic. Sadly that’s part of the logic board that needs service.
You might want to try the other side ports a try to see if thats better as your system has two Intel JHL6540 Thunderbolt 3 controllers (light Blue marked chips)
Otherwise its within the SMC logic which you could have hit while disconnecting the battery (light Green marked chip)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jonathan B 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 54
