주요 콘텐츠로 건너뛰기
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
370 질문 전체 보기
new nintendo 3ds xl no bluelight only orangelight when its charging
I recently bought a new 3ds xl it worked well until I accidentally took out the battery while it was running. I wanted to change the housing of it so I swapped it, but the problem started when I was testing if it’s working properly, I temporally connected the battery without the case it showed red light which means low battery so I thought need to turn it off so tried to press the power button but cause I was using both of my hands I needed to use one of them. my hand slipped and the battery just got disconnected… from what I searched it might be a fuse or diode problem but I don’t know how to read the multimeter.
Update (11/18/2021)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
did you check all the ribbon cables are seated right and just in case reseat them? if it is a diode you can test a identical one on the board to find the OHM reading and knowing that fine one that isn’t the same as the rest.
해당 답변은 도움이 되었습니까?
점수 0
댓글 7개:
I think the cables are all okay...
but one of the diodes (I'm not sure if it's a diode) showed some differences from others. The one that was near the internet cable showed 1.90 and I reversed it showed nothing...? is that the problem?
@prame0627 which one I need a picture. and it depends. some only allow flow in one direction. the black lead of the meter is were the flow starts and goes to the red side
I uploaded the things that I checked
@prame0627 OK now we are getting somewhere! that 0.00 is probably the bad one. it may even be affecting the one next to it that is 1.9 and 0
what were the other silver tan ones showing just to verify they are not showing 0/0?
when you tested the 1.9/0 one did you do it a couple times?
BTW a 0/0 is a dead short!
the one on bottom that is close is probably fine.
The other one idk. never seen it half it but only one direction but I do know there is resistors that do half steps.
I think the biggest next step is to find the part numbers for those 3 or a diagram with the information so you can buy some. luckily they are really cheap.
댓글 2개 더보기
댓글 달기
귀하의 답변을 추가하세요
prame0627 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 30
전체 시간: 619
