주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
I recently replace my iPhone 7 screen and my screen doesn’t turn on.
So I recently replaced my old iPhone 7 screen since the ribbon cable snapped. And when I replaced the screen and booted it up it needed to charge. And the charging logo and everything was there so it seemed that everything was going perfect. But when I booted it up with it havin full battery I turn it on and see no apple logo and then the screen is then on for like one second. Like it flashes when I turn it on once and then doesn’t happen again unless I turn off the phone completely and then turn it on and the same thing then happens over and over again.
Update (11/18/2021)
Update (11/18/2021)
here this is what I does
Update (11/18/2021)
here’s it in slow motion
Update (11/19/2021)
but now it doesn’t work again I’m super stressed. As soon as I opened it to put the screws back where the the connection to the motherboard it happened again
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 21개
I would double check the screen connectors. It might just be a faulty conncection.
Turn it on then connect it to the iTunes or 3utool to see if it detected to computer.
Let me know the results
@honakrisi this is my 3rd replacement screen and the first time it worked but then the cable snapped and then the 2nd one was a faulty and now i bought this again on fixez.com idk what to do really. i'll keep you guys updated
I know but the real thing I want to know if it detect by the iTunes or 3utool.but if this is hard for you try this only if you know your battery having some charge...turn on your phone while plugging charger then leave it for two minutes then unplug the charge then plug it back...to know if you can feel vibration and sound
@johnkangta I feel a vibration and i hear a noise but on itunes and 3utools it does not recognize it
댓글 16개 더보기
댓글 달기
답변 2개
선택된 답변
If the phone has a passcode it will not be detected on your PC or Mac until the passcode is entered. Since the phone seems to be booting the next thing you need to confirm is.
·         Is there image but no back light? When you boot the phone shine a torch on the screen and see if you can make out the apple logo. If you can it is likely you have damaged the back light circuit or the connector on the logic board.
·         If you cannot make out an image I would suggest trying another screen or at least seeing if the screen will work on another iPhone 7. This might not be possible but you somehow have to rule out a faulty screen.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I’ve had 3 screens that did almost the same thing so there’s no way they’re faulty
댓글 달기
mostly unscrew this screw
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
That screw has been unscrewed already and still Nothin
How do I post pictures
Last option if doesn't work connector deformed during replacement or short circuit (Incase you accidentally connected/disconnected display while battery connected)
My very last option
Connect only 3 flexes 1.power button flex,2.display flex,3.Battery
If not change back house or take logic board out the power it using power supply while display connected.
I had the same problems and I solved them with those methods.
If nothing changes diagnosis display circuit
댓글 달기
귀하의 답변을 추가하세요
Lacky KingChuck 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 182
