주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
Battery Model A1185 bloated, case opened.
Battery case "split" open, like forced out by swollen chemical elements inside. A gap on one side of almost 1 cm wide. However still functioning normally, ie. charges/discharges. The cover don't sit flush with back-side of MacBook. How do I de-swell Battery so it sits flush in the slot again?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
If one of these replies answered your question please hit the "accept" icon to the upper right of the answer you liked so we can take it off the unanswered list. If it didn't please amend your question and ask again.
댓글 달기
답변 2개
선택된 답변
I've got one just like it sitting on my desk. Nasty aren't they. There's really nothing you can do. High end batteries can be had at www.batterybiz.com, replacement battery at www.hienergybatteries.com for 40% less. Also here MacBook Battery
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
You can try 1-800-SOS-AAPLE and complaint about it and ask for a warranty exception, this is a wel know problem and I think there was a recall at first.
Mine is open in the middle on the bottom 4 mm on one side and 5 mm on the other. I didn't call Apple because I didn't want to raise my blood pressure yelling at them and have a stroke. Let me know if it works. This is not a cheap, wait, let's say inexpensive battery.
댓글 달기
But please discontinue using the battery. The reason there was a recall on them was because they would catch fire. If yours is bulging, remove it from the computer until you replace it and Follow the instructions left by " Mayer" for the rest of it.
Another vender I like is www.fastmac.com They sell good battery's also and they are usually stronger than Apples
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Do you know anymore about the recall?
AFAIK, the battery "repair and exchange" program on the MBP batteries has concluded. Here's a blog article talking about a bulging battery. It may still be worthwhile contacting Apple and seeing if they will replace it. Either way I agree you should stop using a bulging battery immediately!
Looks like they've pulled that article, the link didn't get me there
댓글 달기
귀하의 답변을 추가하세요
peter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 8,141
