주요 콘텐츠로 건너뛰기
Released in May 2020, the 13" MacBook Pro features quad-core Intel 8th generation Core i5 and i7 processors, and Intel Iris Plus 645 integrated graphics. (Model A2289/EMC3456 with two Thunderbolt 3 ports)
78 질문 전체 보기
Weird display issue after a fall
I have a MacBook which had a fall but the display isn’t broken just get a weird glitch every now and then, I was wondering if reseating the display cable could help or if the display is damaged beyond any repair
when I flex the display a little it goes away and works just fine for a while even closing and opening the display.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
To make sure connect your system to an external display if the externals image is good when your internal is messing up then you have a problem with the internal display.
댓글 달기
답변 1개
Not good ;-{
You’ll need to find someone with very good micro-soldering skills to see if they can save your display.
What you are seeing is the LCD displays ribbon cables to the T-CON board have become disconnected. Hopefully its just the solder joint on the T-CON board then its the T-CON board which is part of the display assembly.
Otherwise its time for a new display time:
  • 13” MacBook Pro Complete Display - Space Grey, Apple P/N 661-15732
  • 13” MacBook Pro Complete Display - Silver, Apple P/N 661-15733
MacBook Pro 13" Two Thunderbolt Ports 2020 디스플레이 어셈블리 교체
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I see, apple quoted me an estimate of $600, If I were to mail this laptop to Rossman repair group do you think it would be less expensive, or how much would a repair like that cost approximately ?
@Manuel Alejandro Roman Leal - You'll need to talk directly with them. There still a good possibility you may still end up needing a new display if they can't fix it.
댓글 달기
귀하의 답변을 추가하세요
Manuel Alejandro Roman Leal 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 41
