주요 콘텐츠로 건너뛰기
첫 번째 iPhone 모델, Model A1203은 4, 8, 또는 16GB 용량과 알루미늄 뒷면을 가지고 있습니다. 수리를 하려면 상당한 양의 비집기와 납땜을 요구할 수 있습니다.
224 질문 전체 보기
질문 마감됨
2g touchscreen not responding
Are the 2G iPhone and the iPhone 1st Generation the same? This link calls it 1st Gen ( http://www.ifixit.com/Answers/Ask/iPhone... ). In any case, I believe I have a 2g, and the touch screen does not respond to touch. I understand that the digitizer and screen are 2 in 1 and that I need the complete part(s) but do not see it on your site, nor the blue prying tools. Can you and me the link to the tools? I saw them yesterday for $2.95 or so.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
not worth fixing..cost too much for the parts.
as the front and lcd and glass are all one unit.
will cost you around £170 and are getting rare now.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks. The problem this 2g is that the touchscreen did not respond to touch ( now wont turn on at all). I read omewhere within this site that the connector might be loose. I tookit all apart, and as soon as one of the cable loosen up, the screen went off. Mind that I could not turn it off due to the screen not responding, or sliding off. It was a fustrating to take apart, so I'll try once more and see if in fact reconnecting everything will fix it, otherwise, it may be just worth recycling. Thanks again.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 2,462
