What pins does the USB-C breakout board hook up to?
So, my controller's USB-C connection port decided to break off, and I am trying to replace it myself, but my issue is I can not verify 100% what each pin on the breakout goes to on a USB-C male port. So far I have:
TP1 - B4/B9 (VBUS)
TP18 - ?
TP11 - B7
TP5 - B6
TP3 - B5
TP13 - B4/B9 (VBUS)
TP16 - B12 (GROUND)
TP(X) is the labeling on the breakout board itself. Any help would be appreciated
EDIT: image links added here:
https://guide-images.cdn.ifixit.com/igi/...
좋은 질문 입니까?
댓글 2개
souswodaem1 post a couple of good pictures with your QUESTION. It might make it easier to properly identify what it is that you are describing. 기존 질문에 이미지 추가하기
oldturkey03 의
Oh that would probably be helpful. I found some images from the IFixIt guide itself:
they refer to it as the "phone connector" on the service guide. My issue is basically the USB C header came off, and for me to make a new one, I need to know where the pins on the USB C port correspond to the 7 pins on the breakout.
souswodaem1 의
