주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ResMed AirSense 10 CPAP 기기 관련 수리 및 서비스 정보입니다. ResMed Air10으로도 알려져 있습니다.
My unit is making a loud noise when I breathe in and out
How can I fix the loud noise when breathe in and out?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 9
댓글 3개
When I breathe, my machine makes a squealing sound. It appears to be coming from the two seals that compress when the humidifier chamber is attached.
의 공유
The water is gone in three hrs in well and no leakes in well. I have to refill every night .
의 공유
I’m not a doctor, though I have been treated 30 years now for Sleep Apnea. I pretty much been through it all.
It is my opinion, you are sleeping still with your mouth open. They do make chin straps , to attach to one’s headgear, also you may want to try the nasal pillows, or what is called a full face mask. It actually just covers your nose and mouth. Those are what I’m familiar with, surely there may be more options !
Good Luck,
Sherwood
의 공유
댓글 달기
답변 8개
가장 유용한 답변
I also experienced this. A sound from within the machine, a sort of wheezing sound that was apparent as I breathed in and out. It was a disturbing sound not having to do with an air leak from the hose, mask, or water tank, as I checked these possibilities first. I discovered the sound was coming from the motor itself. In my case, the motor in my machine was just five years old. I was able to replace the motor quite easily with the aid of a couple of YouTube instructional videos which were easy to find. I was able to purchase a replacement motor which I found on that large online shopping site. I believe it cost $129.00, and it arrived the very next day after I ordered it. I believe that just about anyone can replace their motor with the aid of an instructional video for which there are several on YouTube.
이 답변이 도움이 되었나요?
점수 10
댓글 3개:
Hello, could you send the link for delivering of the motor? I think, my problem is like yours.
의 공유
Hi, so has this fixed the loudish sound while breathing and exhaling.
의 공유
Just replaced my motor using a guide here. The sound disappeared with the instal of the new motor. Here is the one i bought: https://a.co/d/bWRwCbs
Here is the guide I followed(please make sure to read all comments and the guide thoroughly before starting): ResMed AirSense 10 펌프 모터 교체
의 공유
댓글 달기
@rdb88385 sounds like a pressure related issue. Double check your device to see if it is related to the recent CPAP recall. If so you want to contact the company and get directions from that. If it is not, then I would still suggest that you contact ResMed (or your local DME company as well as your health care provider) and see if they can guide you. You are obviously using/needing it and we all want you to stay well
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Re the squealing noises- That’s a definite problem with Resmed machines. I put a tiny smear of Vaseline at the back of the humidifier where it meets the silicon seals. Every so often I use a baby wipe or something similar to clean it off the seals and humidifier then reapply. That’s been working for me for over two years now. You can put some Vaseline around the edges too of the noises persist. I hope that helps Rockie.
이 답변이 도움이 되었나요?
점수 3
댓글 6개:
Edwina! THANK YOU! This helped a lot. It didn’t take away the sound completely but it certainly helped reduce it significantly! I couldn’t sleep all night! 🥹
의 공유
I have tried that as well as pulling my humidifier out during non use to avoid constantly compressing the seal. Both your comment and latter action above have helped the problem. I have a new part on the way. YouTube has a video on how to install the new seal.
의 공유
My c-pap machine is making loud noises when I put it on . I’ve changed the head gear, heating hose, water chamber and air filter. The noise is coming from the machine please help
의 공유
Just replaced my motor using a guide here. The sound disappeared with the instal of the new motor. Here is the one i bought: https://a.co/d/fmJu84y
의 공유
My resmed 29 airflow bibap make a noise when ii inhale that i cant even fall asleeo
의 공유
댓글 1개 더보기
댓글 달기
The noise is generated due to the blower assembly check the assembly .
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Tighten the strap system as it shouldn't make noise and if it starts whistling put a small bottle of water on the door to the water tank. To stop the face farts tie a handkerchief over the gasket so it covers it and the gasket will last YEARS.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Face farts - best thing I have read in a long time lol
의 공유
댓글 달기
may be water condensed in your air tubing. Sounds loud. drain water if present.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
We had two brand new machines with this problem. We finally bought new ones of the latest model. Totally silent.
Resmed would not admit to any problems. My therapist says this is not uncommon-- fix is to replace motor or replace total unit.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Defective cpap unit is often the case. Motor is bad. Replaced the unit and no more problems. More common than you would think.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
roger bailey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 30
지난 7일: 199
지난 30일: 590
전체 시간: 30,012
