Backlight won't work. My question: Which Fuse do I need to bridge?
Hello, my question is in the title.
The PSP (Mod. 200x) is operating completely normal. It was unused for many years now and when I turned it on the display was apparently not functioning. After I shone some light on it while on I could clearly see that the problem was not with the display but with the Backlight. I’ve read that many people just bridged it with soldering metal and it worked just fine so I want to bridge the fuse too but in order to do this I need to know which fuse exactly I need to bridge.
I will add some pictures of the Mainboard. What I’ve done: I disassembled the whole console, cleaned most contacts with Isopropyl Alcohol.
It’s confusing because I have seen many videos but most of them are with the 100x, 300x models or the PSP Go. And the sources I found on the 200x model (which I have) always mean different fuses to be bridged/fixed.
좋은 질문 입니까?
댓글 2개
Hi @spicylemon is repaired?
FKCrew 의
@fkcrew Hi, unfortunately not. I did not find the specific part but I guess I'll order a broken psp2000 and harvest the needed fuse. I'll let you know as far as I have an update
Seph 의
