주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab A 10.5 includes two model numbers, the SM-T590 (Wi-Fi), and the SM-T595 (LTE).
6 질문 전체 보기
Samsung tab A7 2020 will not power on, does not show charging
I changed out my charging port, put it back together and nothing. It will make a sound when I plug it in otherwise absolutely nada. I double checked all connections. I have tired holding the power button for as long as 1 to 2 minutes, same with power and volume down. I unplugged the battery for 10 minutes and removed the sd card. I have trickle charged it with my computer (does not show up, so its not on or has 0 battery) and travel charger. Nothing. I think the batter is at 0. I am on the verge of tossing it but I feel like it is something easy (plus it's only a year old) my next step is to try to jump start it with a 9 volt battery. Otherwise I am at a total loss. Help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
@pittypat. your battery will not charge if it is below it's threshold of ~2.9V-3.0V. Of all the thing you have already tried, replace the battery. that way you have a Known-Well starting point. After that you will have to dig down deep
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Sounds like you likely have a defective charge port.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I just put in a new port.
댓글 달기
귀하의 답변을 추가하세요
pat allred 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 54
전체 시간: 1,701
