which Size(mm) using in Caddy 9.0mm or 9.5 Size.
It is possible ,I am Upgrading HDD & SDD IN Lenovo G50-80 LAPTOP l am HDD using Caddy .it Working or Not .If it is working which Size(mm) using in Caddy 9.0mm or 9.5 Size. Thank you.
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
If you are replacing the HDD in the laptop with a 2.5” 7mm sata SSD you will need a 7mm to 9.5mm adapter (supplier example only) to sit under the SSD so that it aligns correctly with the port connector.
Here’s the ifixit Lenovo G50-80 80E5 Hard Drive Replacement guide that may help.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 896
