My phone shutting down itself
Hello, I have a with my poco that he is shutting down itself, also he disconnects from wifi and won’t connect until he shut down. And when this happened he won’t register my sim card.
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
To prove whether it is a software problem or a hardware problem you may have to perform a hard reset
Be aware that a hard reset will erase all your data and downloaded apps. It will restore the phone to its factory default condition.
Backup the phone to the cloud or a computer before performing the reset. Also if there is a Google account tied to the phone, you will need to know the account name and password to access the phone once the reset has been performed due to the FRP lock (factory reset protection) being enabled by the reset.
If you’ve already done a hard reset (you didn’t mention if you did) then it is a hardware problem. So dropping the phone may have contributed to the problem. Here’s the ifixit Pocophone F1 Repair guide that will help you to open the phone and check for any obvious problems e.g. loose connections or cracks in the systemboard etc.
해당 답변은 도움이 되었습니까?
I gave the cell phone a hard reset after battery change, but I think it has something to do with this chip https://forum.xda-developers.com/t/pocop...
@Peter Matava
If you're willing to take the chance you could reflow the chip and check but I don't know what temp you would need or for how long.
You would need to dis-assemble the phone and remove the systemboard to prevent damage to other parts of the phone when doing this.
You could always try contacting the person who fixed it and ask them. Here's their email address from the link you posted in your comment - servis@mikroteh.hr
24 시간 전: 5
7일 전: 18
30일 전: 60
전체 시간: 345
5 Comments
Hi,
Does it shutdown with the charger connected?
Has the phone been dropped or gotten wet at all?
jayeff 의
No its random .Yes phone been droped but no wet.
Peter Matava 의
@Peter Matava
If it doesn't shut down when the charger is connected it may be a problem with the battery
jayeff 의
Battery been replaced
Peter Matava 의
Hi, i'm having the exact same problem. So this might be software
Nicolae Ciobanu 의
