주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
F23 code - Thermistor needs replacement?
I get F23 code on my kenmore elite dryer. Code means thermistor needs replacement. I replaced it and i still get the same error code. Should i replace the whole heater assembly ?
Update (02/18/2022)
model number is 110.C87892601
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
An F23 code could also mean that there is some other problem with the outlet thermistor circuit i.e. control board or thermistor harness wiring and not just a faulty thermistor
Here’s the tech sheet for the dryer.
On p.7 Test #4a it details how to check if the outlet thermistor circuit is OK
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
i did everything, asked above. It worked for 3 cycles the the flashing pf23 code returned. this is very annoying.
댓글 달기
답변을 추가하세요
simon benzekri 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 585
