How to take a broken headphone jack out of the headphone slot?
My friend broke his headphone jack in the headphone slot, soo how do you take a broken headphone jack out of the headphone slot?
좋은 질문 입니까?
좋은 질문 입니까?
Hi Ben,
That situation happens often enough that they've designed a tool specifically for that job. Although you can find them many places like Amazon and eBay, you can support iFixit's repair efforts by buying it right here.
해당 답변은 도움이 되었습니까?
Thanks, but I already took it apart.
@nytryder26 you might be able to open it and push the broken pin out from the top of the connector
해당 답변은 도움이 되었습니까?
Are you willing to replace the headphone jack? If so, follow the dissasembly guide. Screw off the back motherboard after everything is taken apart, and then you should be able to just take the headphone jack out and put the new one in. They are loose, so no soldering required.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 6
30일 전: 35
전체 시간: 1,236
댓글 3개
are you confident enough to open the controller?
Logixal 의
@logixal If I have to open the controller, sure.
NR26 의
@logixal Ok thanks
NR26 의
