주요 콘텐츠로 건너뛰기
Lenovo Legion Y530 Black screen after RAM upgrade and repaste
I’ve repasted my Lenovo Legion Y530, and also upgraded the RAM. I was stupid and forgot to disconnect the battery before the process.
However the laptop worked fine for an hour after reassembly, but then the screen suddenly went dark. (the connected external monitor is dark as well)
The device still starts up (windows welcome sound), the fans are spinning, keyboard lights are on, but the screen remains black
I’ve tried battery removal and discharging, and also tried to enter the BIOS but all i got was 12 short beeps followed by 1 separate beep. I’ve checked the Lenovo Beep Codes, but couldn’t find an exact match for this pattern.
Did I just kill my laptop? Is there any hope for getting it back up without motherboard replacement (which is not an option)?
Lenovo Beep Codes: https://support.lenovo.com/us/en/solutio...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
Hi @folt,
My first thought (as it worked for an hour) is that something wasn't quite put back where it needed to be and has wiggled loose. Have you tried opening it back up and double checking that you everything unplugged in your repair was re-connected firmly and clamped back into place?
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi @folt,
To add to Amber’s answer - Have you tried Fn+F6 to increase display brightness or Fn+F7 to toggle between the laptop display and an external display or with the computer off press the Novo button (little hole near side USB 3.1 port) using a paper clip (something without sharp tip) to start the BIOS setup utility? Lenovo Legion Y530 Hardware Maintenance Manual may help: https://usermanual.wiki/Lenovo/legiony53...
I tend to agree with Amber that something, especially LCD cable connector, was not connected securely or correctly. Moving the lid would certainly loosen it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Usually, unless you do a display service the backlight fuse survives. Now yes, never do that again but I wouldn’t be surprised if the fuse is fine. I’ve made this mistake with RAM and SSDs before, and I was fine.
Your best bet is to disconnect both the primary and CMOS batteries for 1-2 minutes, hold the power button for 30 seconds and reconnect it to reset the BIOS settings back to default and see if that helps.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Update! I tried (re)connecting everything as You guys adviced. Everything was OK.
On Windows 10 I had no success but after booting the laptop with an other SSD (Linux) an external monitor became fully functional. The laptop screen displayed a VERY dimmed unreadable screen but it was the Ubuntu desktop.
What I tried/noticed:
* When I switched the main display to the external monitor (to conveniently access desktop), the external monitor became very dimmed as well, and UI elements did't respond to clicks.
* After it switching back, it was good again but the laptop remained black in both setting.
What I also tried, with no effect:
* Disconnect the battery
* Clear CMOS
* Discharge the device by holding the power button for 30s+
What I can’t do:
* Access BIOS, I get the same beep codes as described in the original post. Even if I could, the screen brightness is not enought to seen&navigate.
Can a motherboard/gpu/cpu(?) be "Partially Dead" with such limited functionality (with no realistic hope of repair)?
댓글 달기
귀하의 답변을 추가하세요
Folt 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 890
