주요 콘텐츠로 건너뛰기
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
51 질문 전체 보기
Replaced Screen. Touch and Pen Problems
I dropped my Surface Pro 5. I ordered and received a new screen through Amazon. For a while, things were good, but then touch and pen functions started to deprecate. I did not drop it again, but I think I may have disturbed something when I replaced the not so protective but cute protective case with a more rugged (and expensive - worth it!) Urban Gear case.
I reopened it. I cleaned out some of the adhesive, mainly from the top where there is some copper (antenna?) This seemed to give me more consistent pen operation. I am thinking about removing and reinstalling the screen now that I know what to do. Maybe I will recover something that I missed on the first pass in the process.
I disabled the two HID touch screen entries in Device Manager, restarted, enabled, restarted. At first, I saw the little gray circles, but the screen cycled off and on a few times. They disappeared.
Do you think uninstalling the drivers will help or harm? I assume this would force Windows (11) to look for drivers again?
I hope it is not a faulty screen, since I am sure my return opportunity is gone.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Yes. I was thinking about reopening and reinstalling. The pen is super consistent since I partially removed the screen and cleaned the excess adhesive.
댓글 달기
답변 2개
선택된 답변
I suspect that you have installed it incorrectly, or some wires have not been properly connected, is it possible to open the screen again and check?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Messing with the driver won’t help, this is entirely hardware.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Leon deVose 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 155
