주요 콘텐츠로 건너뛰기
Curved screen LED monitor released by Samsung in May 2015, identifiable by the model number S27E510C.
Backlight briefly flickers on - which is the most likely component?
I have a Samsung S27D390H - a 14VDC LED backlit display. They’re similar enough that I think asking here is appropriate. I haven’t done a backlight diagnosis since I haven’t needed to before, so I’d like someone who has more experience narrow it down since they’d likely know right away, as I have very specific symptoms.
  • Power always remains on, LED indicates this
  • Backlight flicks on for a fraction of a second every few seconds, then turns off, ad infinitum
  • The HDMI signal I tried from my laptop displays properly in that fraction of a second, and the backlight appears uniformly activated during that fraction of a second, whether on HDMI or VGA. So, signal processing is good, and it doesn’t *appear* to have actual backlight dead-zones
I have a feeling this is a simple single-component failure. Can someone point me to the most likely culprits?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
While the backlight is off on the TV and a signal is connected, if you shine a flashlight onto the TV screen, do you see a dim image?
댓글 달기
답변 1개
가장 유용한 답변
Hi @beefsticks ,
It maybe quicker to invest in the service manual as they have dis-assembly instructions, schematics and parts lists which make it easier to find out what’s wrong and fix it when you do.
There may be a problem with the backlighting power supply, connections etc or it may be on the mainboard turning the backlights on and off for some reason.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Beefsticks Wellington 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 324
