주요 콘텐츠로 건너뛰기
Why is there a "do not disconnect" logo on my screen
We just bought a used iPod and there is no booklet with it. When I plugged it in to my computer via a USB connector there is now a sign blinking and saying "do not disconnect". Is there a problem???
Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
i am using 7th ipod nano and it says okay to disconet but it just stays there i tried reseting it and puting it on disk mode not of this worked
댓글 달기
답변 7개
선택된 해법
it has a do not disconnect on it because your iPod is trying to talk to the computer. If you disconnect it without first removing it from the computers desktop you can corrupt both the iPod and the computer.
Go to : http://support.apple.com/manuals/#iPod and locate your iPod and download the manual.
Take care
이 답변이 도움이 되었나요?
점수 6
댓글 달기
가장 유용한 답변
This is normal. There is not a problem. You simply have to go into your iTunes program and 'eject' the iPod. The eject icon is a triangle over a bar just to the right of where it lists your iPod on the left column in iTunes.
Roll your cursor over the triangle and press once. After just a couple of seconds, your iPod will be ready to disconnect and the "do not disconnect" logo will disappear.
Good luck,
Frank
이 답변이 도움이 되었나요?
점수 10
댓글 2개:
Hi this is also happen to me i see the iPod icon on my iTunes but as soon as i eject it from iTunes the ipod icon goes away...this normal??
Hi this is also happen to me i see the iPod icon on my iTunes but as soon as i eject it from iTunes the icon goes away...this normal??
댓글 달기
toggle hold switch 5 times, then hold center button and menu button at same time for 10-20 seconds. Sounds crazy, but it worked for me!
이 답변이 도움이 되었나요?
점수 4
댓글 5개:
Thank you for sharing this! It worked for me too! I didn't want to have to recover and reset it.
but this happens every time i connect it
Haha, now my ipod is sad. help
it happend every time iconnect it then how can down load music
Hey I did what you said and it worked right away. I really appreciate you doing this. So many people have different ways of doing things with Apple but they seem to work very well for me the first try out. You’re the greatest thanks again and keep adding comments and answers for any issues that come up with iPad Mac of any type and OS X programs. Thank you so much for your help
댓글 달기
@debbie
Make sure you use iTunes, and connect your iPod.
Select your iPod in the navigation panel on the left, Devices section.
Now use the Music button in the top menu.
Select to synchronize only "Selected playlists".
Only the tracks used in the selected playlists will be synced to your iPod.
The other tracks in your music library will not appear on your device.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Super,works like a charm!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I’ve tried everything and I cannot get the do not disconnect off of my Ipod. Please Help!!!!!! It doesn’t even show my Ipod Icon in ITunes…..
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
exactly the same for me Carmelita !!!!
and for me, frustrating
댓글 달기
u need to disconnect! If the do not disconnect is still present, theoretically it will boot back into iPod software
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 19
지난 30일: 96
전체 시간: 38,177
