주요 콘텐츠로 건너뛰기
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
157 질문 전체 보기
Looking to fix the right stick click on an Xbox One controller
I have a 1708 Xbox One controller that does not register the right stick click.
I've opened the controller up and looked at the clicker mechanism on the joystick and it seems to make contact just fine and push the button down. But it does not register on a button tester.
I've also installed a new joystick and still see the same issue. I'm assuming this is a board issue at this point? Not sure where to look on the board however.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
It is probably a board issue.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Gotcha. Seeing if I can grab a bit more information about it. Is there something that can be replaced on the board or would it require a new board entirely?
@meattacos You could technically resolder a new part, but there is no way of knowing what part failed, therefore, the board should be replaced.
댓글 달기
귀하의 답변을 추가하세요
Francis Carow 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 243
