backlight turns off any time in an hour.
My issue is a bit different. Sound, amblight and picture is ok but backlight turns off any time in an hour. İt happens after picture is displayed from any source. If no picture then no problem. Changing tv may be better then change main board.
Güncelle (21-03-2022)
좋은 질문 입니까?
Serkan atan what exact model is your TV? What do you mean by this "after picture is displayed from any source. If no picture then no problem. " The "If no picture then no problem." really has me confused.
oldturkey03 의
İt is 48pfs8109/12.
I didn't install channels after reset tv, back lights made no problem.
Then I setup channels and start to watch a channel, tv turns off screen back lights. Sometimes some seconds later, sometimes it lasts more then 30 minutes. When I start the tv, if I am lucky i can use tv a little more then turn backlight off again.
Serkan Atan 의
Screen LEDs are the problem. After the change of the screen LEDs, tv is fine now.
Because of the fault in the LEDs, main board turns the LEDs off to protect the power card or itself, as I understand.
[image|2616818]
Serkan Atan 의
