Samsung SSD NVMe 980 Pro
Can I replace the Apple SSD with Samsung SSD NVMe 980 Pro, is that possible?
좋은 질문 입니까?
좋은 질문 입니까?
While some have done it. the reliability of the drive being force fitted becomes the issue.
I’ve removed many of these M.2 SSD’s and the adapters needed from many iMac’s and MacBook Pro’s. The rub is Apples interface carries other signal lines which only Apple SSD’s and SSD drives which properly match that controls housecleaning (garbage collection & wear leveling) that the M.2 SSD and its adapter doesn’t offer. Some adapters fail to connect properly and as this is an adapter there’s a higher CRC error rate when there is a large data move.
Bottomline as much as I had wished Apple would have embraced the M.2 standard (as it would have made things so much better) they didn’t!
Given the amount of work needed to even get to the port I really think its just smarter using the correct drive Apple or OWC which are designed to work.
As far as getting the Pro Vs the EVO version of the SSD I wouldn’t waste the money stick with the EVO if you are head strung on doing it.
Here’s the guide: iMac 27" 2017 Blade SSD Replacement and the needed part iMac Intel 27" (Mid 2017-2019) SSD Blade Upgrade Bundle
해당 답변은 도움이 되었습니까?
I tried it. (The 980 pro in an iMac 27” 2017)
although it seems to be working, I started getting hangups and restarts, along with inexplicably long startup times
the Blackmagic speed test app reported anywhere between 0 MB/s writes to almost 3000 MB/s
the read speed was always ok (around 3000)
A lot of times it was struggling to write at 30 MB/s
I changed the adapter hoping this would fix it.
it made it worse. constant auto-restarts, to the point that it became completely unusable.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 25
30일 전: 56
전체 시간: 3,005
