주요 콘텐츠로 건너뛰기
A2115 / 2019 / 프로세서 3.0GHz 6코어 i5부터 최대 3.6GHz 8코어 i9까지. 2019년 3월 19일 출시.
131 질문 전체 보기
CTO iMac 27 5k 2019 with 2TB Apple SSD. Does this include a SATA cable
It would be an iMac 27 5k 2019 purchased in a CTO configuration. It comes pre-ordered with a 2TB Blade SSD from Apple and therefore does not include an HDD (Fusion drive).
My question would be if I buy a SATA SSD installation kit. will my HDD Data and Power Cable be included in my iMac? If not, what cable can I replace?
( There would be a cable detailed on page 88 of the Repair Guide PDF. ***``Service Manual - iMac 5K 27-in (2019).pdf )
The end result would be to have one Blade SSD and one SATA SSD in my iMac.
Thanks for everyone's help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Apple does not install the SATA / Power cable 923-00664 when you get a blade SSD model you’ll need to buy it if you are adding a SATA drive (HDD or SSD).
Here’s the location of the connections, the Orange marked is the data and the Red marked is the power
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Thanks for the quick reply Danj.
Then the brain was confirmed.
Where can I find this SATA / Power cable 923-00664 cable here on iFixit?
Sorry, iFixit doesn't offer this cable here's one source iMac 27" Retina 5K Hard Drive Combo Cable (L15/17/19), Apple P/N 923-00664
Thanks for the help. That's how I'm going to proceed. :)
@amp_hw_rep - Don't forget to accept the answer - Thanks!
댓글 달기
귀하의 답변을 추가하세요
Peter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 421
