How do I get a stuck disc out.
My wii will not turn on and it has a stuck disc inside it, how do i get it out.
Update (09/16/2015)
First, lift open the GCN port and take off that piece of the faceplate. Unscrew the little black philips screws (i believe there are 9). that piece will come off . Under the wii there are white bumps that you can pry off as well certain stickers. check a guide to see where as I'm currently at school. these are slightly larger philips screws. there will be the same instance on the side of the wii that you can lay it on where you can use a spludger except these require a deep triwing screwdriver. Open these up and you will see extra triwings on the face plate of the wii. You can manually trip the sensor and eject the disc.
좋은 질문입니까?
댓글 13개
it doesnt work plx help :(
gerardo 의
gerardo, what does not work? what have you tried?
oldturkey03 의
How to get the Wii to sence the disc
Domnic Paccione 의
how to fix stuck disc in wii u
elyossiahaya 의
The disc is wasn't come out
Paul Kim 의
댓글 8개 더보기
