주요 콘텐츠로 건너뛰기
갤럭시 A20s는 2019년 9월에 삼성에서 출시한 중급형 안드로이드 스마트폰입니다. 모델 번호 SM-A2070, SM-A207F/DS, SM-A207M/DS로 식별할 수 있습니다.
Why is my phone freeze when connect wifi
My phones gets slow when ever i connect to wifi and apps take long to respond
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Have you checked that the software (aka firmware) for the phone is up to date and also for all the apps that are installed? Have they been updated lately? Open the Play Store app and check.
Try starting the phone in safe mode and check how it works when you turn on WiFi.
If it works OK then a downloaded app may be the cause of the problem. In normal mode it may be connecting to the WiFi and downloading in the background unbeknownst to you and this could slow everything down. A downloaded app is one that you have downloaded and installed on the phone.
In safe mode only the apps that came pre-installed on the phone can be loaded on startup - not all are but some necessary ones are but when you download and install apps that you want, some are set to load on startup and their permissions settings may allow them to go online as soon as a connection is established.
Check the permissions in the settings for each downloaded app and check if you want them to go online without asking you first. Go to Settings > Apps > select the required app > Permissions
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Jacob Ontlametse 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 34
전체 시간: 1,894
