주요 콘텐츠로 건너뛰기
Repair guides and troubleshooting for Acer Predator 17.3" laptops, a group of high-end gaming computers from Acer. These laptops features a 17.3" display, dedicated GPU, and a modular bay for either an optical drive or cooling module.
16 질문 전체 보기
Battery not taking a charge?
My acer predator laptop all of a sudden stopped charging, one night it was charging just fine and the next day it just stopped, it wasnt moved from its spot or dropped or damaged in anyway, just stopped charging
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 3개
Try taking out the battery and starting it
Hi @ josh price,
What is the model number of the laptop as printed on the label on the bottom of the laptop?
Have you tried a different compatible charger to see if that worked in case the charger or charger cord is faulty?
@jayeff im about to order a new charging cable, will update when it arrives
댓글 달기
답변 1개
선택된 해법
I will suggest checking the charging cable first, if there is a charging light indicating on your laptop and still doesn't get charged then under the laptop you will find a small battery reset buttonhole, using any pin you can reset the battery. Hope this will solve the problem.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
josh price 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 27
전체 시간: 1,636
