Why my battery is too weak
좋은 질문 입니까?
Hassan morray Koroma the battery is pretty much the only strong point on this phone. You should explain to us what you mean by the battery is weak. If you need to extend your battery life use the suggestions from here The battery life is only as good as you use it. The more you use it the shorter it gets.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 513
댓글 3개
My battery is so weak
Dore Mone 의
Mere mobile ki battery ki life dheere dheere Kam Ho rahi hai
Md Azad 의
not charge up properly/long enough
antonio 의
