주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
탑승형 잔디 깎는 기계. 제로 턴 반경 잔디 깎는 기계, 50인치 커팅 데크, 유압식 자동변속기.
Why one drive side has less power than the other?
I actually have a Craftsman Z6900 zero turn mower, but that wasn't an option to select.
My problem is that the drive on the left side is not producing as much power as the right side. On level ground it operates fine, but as soon as I have to go up a hill I have to fully engage the left side (and I hear a groaning sound, like power steering in a car when the fluid level is low) but the right side can stay just partially engaged and provides plenty of power. I have read that my mower has a hydrostatic transmission, but I have no idea if this one is serviceable or how to do that if it is. Any ideas? Mahalo.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
@phillfam10 looks like your mower uses a Hydro-Gear 2200 Integrated Hydrostatic Transaxle EZT Series for the drive. Those drives are a bit tough to work on etc. I would check the oil,and purge the unit. After that you may need to check the bypass and see if that is within specs. For all off that refer to the SM Hydro Gear 310 2200 EZT
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
David T Phillips 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 24
전체 시간: 1,366
