주요 콘텐츠로 건너뛰기
Repair guides and support for televisions manufactured by Sony.
with a led tester the backlight is working fine.
Tapping on my back side of tv (55x9005c) does not solve the issue. The tv is starting and sound is working. With flashlight I can see the menu of the tv. But the backlight is not turning on. with a led tester the backlight is working fine.
which part should I replace?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@harunie check the voltage coming from the power board on the Backlight connectors. If your backlight works with the tester but not with the TV it is possible that this is a power board issue (no voltage or low voltage supplied) or a main board issue. The main board tell s the power board to turn the backlight on. Check the voltage on the connector from main board to power board for the BL ON signal. My prime suspect at this time is the power board. If you need further help on this post some good pictures of your boards with your QUESTION. That way we can see what you see. 기존 질문에 이미지 추가하기
Update (05/04/2022)
BL_ON (L or H): IC9017 #18pin should be ~3V
The BL_ON should change when the TV is turning on. That is because it tries to turn the backlight on. If those do not turn on with that signal you would get an error code blinking. Since the BL_ON is generated by the Main board, you should check that next. Post some more very clear and close pictures of your boards. to see if there is /are fuses on the main board. The voltage on the BL should be relatively high so set your meter to the 300VDC range and then bring it down if need should be.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@oldturkey03
What should be the voltage coming from the psu and the backlight connection?
And what should be the voltage on the connector from main board to power board for the BL ON signal?
댓글 달기
답변을 추가하세요
Harun 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 8
전체 시간: 337
