주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for Lenovo's line of consumer-oriented laptops, the IdeaPad series, first announced January 2008.
What bits are these
, I have a lenovo idepad duet 3 10ilg5 but their doesn't appear to be a teardown of this device
Edit here's the pdf but when I search online can't find anything on the screw
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I updated my answer with the information from the picture you added. :D
댓글 달기
답변 3개
I can tell you that it's a Torx bit, but it's hard to see what size it is and I can't find it online.
But I would guess the bit size is somewhere between T3 to T8.
Update
Thanks for the documentation, they are M2 Torx4 (T4) screws.
From my understanding, the "L" just means that it's one of that L shaped tools normally used for Allan/hex keys. So a normal T4 bit should work without any problem.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I updated the range of bit sizes, I started thinking about this answer after closing the computer yesterday and the bit sizes I wrote were probably way to big.
Sorry if that confused anyone!
댓글 달기
가장 유용한 답변
Appears to be a Torx. Probably somewhere between T5 and T9. I'm not seeing a pin in the center, so it does not appear to be Torx Security.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Mohammed Musa you are right. No teardown or guide for it yet. Download the maintenance manual for it from here to work on it. While you do so, create a guide for the next person that may need one. It's really easy to do and will help https://www.ifixit.com/Guide/new the next person.
Yes, the screws are regular TORX screws. Those are M2 screws so I expect it to be around the T3 to T5 range.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Mohammed Musa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 31
전체 시간: 391
