주요 콘텐츠로 건너뛰기
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 질문 전체 보기
My pc has no audio
I got a new pc and it has no audio, I checked the speakers, I tried headsets and i updated the drivers but it doesn't work
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi @aggeloslois
What is the make and model number of the motherboard?
Have you checked the audio settings in BIOS?
What is the status of the audio controller as shown in Device Manager > Sound, video and game controllers > right click on audio controller entry > Properties > General tab > Device status box? Does it say that "this device is working properly"?
hello @jayeff
my motherboard is ms 7751 rev 1.2
https://www.msi.com/Motherboard/z77agd65...
Also, no, I haven't checked the BIOS and in device manager it says that its working
댓글 달기
답변 1개
가장 유용한 답변
Hi @aggeloslois
This is a very old motherboard so are you sure that it was working OK before you got it?
Looking at the user manual Ver.1.1 was issued in 2012 so Ver. 1.2 wouldn't be much newer. The motherboard support link you posted shows Ver.2 which is also from 2011/2012
There is a setting in BIOS that enables/disables the HD audio - (go to BIOS > Advanced > Integrated peripherals > HD Audio Controller) although I would have thought if it were disabled that it wouldn't show in Device Manager but still worth a look anyway.
If Device Manager shows it working OK then it means that the audio controller is being detected by Windows but this doesn't mean that the audio output is OK, just that the OS can talk to the audio controller OK.
How did you try to test the audio?
Check that with the speakers connected to the rear audio jack on the motherboard that when you go to Control Panel > Sound > Playback > click on Speakers > Properties that it shows the speakers are connected to the rear jack and that Device usage: is set to Use this device (enable).
Click on the Sounds tab to test the audio
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I've tried everything you told me but it still doesn't work
댓글 달기
답변을 추가하세요
Aggelos lois 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 380
