주요 콘텐츠로 건너뛰기
The third revision of the classic Xbox Wireless Controller was released in November 2020, bundled with the Xbox Series X and Series S. This controller is backwards compatible with previous Xbox One consoles, and PCs.
20 질문 전체 보기
How would you fix the left bumper?
The left bumper on my Series controller stopped clicking. The bumper now just squishes and does not record the button press.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
I'd probably guess that replacing the bumpers would help. iFixit sells replacement bumpers here. There isn't a repair guide for this, but you can follow this disassembly guide up to the part where the bumper is removed, swap in the new bumper, and then follow the video in reverse to reassemble. If this doesn't work, your best bet is most likely just sending it to Microsoft for repair, or even just buying a new controller.
Replace your controller's bumper assembly compatible with Xbox Series X model RRT-00010 and RRT-00013 gaming consoles. Fix issues like a cosmetically damaged or bent bumper cover. 이미지
제품
Xbox Series X/S Controller Bumper Assembly
$9.99
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Usually just try to replace it (it's actually cheap and available) but if you don't have a good soldering skill you will have nightmares with it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It’s is not pressing down correctly
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
David Evans 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 59
지난 30일: 156
전체 시간: 11,492
