주요 콘텐츠로 건너뛰기
Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
111 질문 전체 보기
I have an unreliable thunderbolt port, the second one works fine,
What could be the issue? The first one works then stops, then works then stops, I noticed some corrosion on the board while replacing the trackpad, but it's very confusing. None of them seem to even affect the tb3 controller.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
How about posting some pics so we too can see the corrosion 기존 질문에 이미지 추가하기
I wiped away the corrosion and it works fine now, haha! Quite interesting, there was corrosion shorting one of the very small chips on the board, almost looks like a tiny mosfet.
댓글 달기
답변 1개
선택된 답변
You may need to replace the MacBook Pro (A1989, A1990, A2141, A2159, A2251, A2289, A2338 Mid 2018-2022) USB-C Board that will require lifting the logic board out to give you access to the screws which hold the port assembly as you can see here
MacBook Pro (A1989, A1990, A2141, A2159, A2251, A2289, A2338 Mid 2018-2022) USB-C Board 이미지
상품
$14.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Wiped away the corrosion and it works now, but Dan's answer is the one that should work for basically everyone. <3 It seems like my problem was on the main board though, not the USB port board!
댓글 달기
귀하의 답변을 추가하세요
wkw030210 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 276
