주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Why does my sound not work anymore?
Hi all,
The problem I'm having with my iPhone is that I'm not able to listen to music anymore. My phone does play sounds, but only when it is docked or when my earphones are plugged in.
It does NOT work without earphones, and the volume slider does not show up when playing music.
However, it DOES make sounds when my alarm goes off or when I'm getting called. Ringtones work fine too.
Anyone know what could be the issue?
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 44
댓글 12개
Mine was doing this as we'll but when I took my headphones out and put it on speaker and made a phone call it started to work again and when I felt the end of my headphones it felt a little wet the problem maybe that there was something in the headphone jack
So my problem is the opposite of y'all's, My phone will say I don't have headphones in when I do and I have no sound coming out of my headphones. I've tried 6 different ones just to make sure it wasn't the headphones and it does the same thing every time. what do I do?
Mine works just fine, as long as I don't have it on the charger. If it's charging, even notification and ringtones are muted, so I've missed important phone calls.
My problem is different, every time I try to listen to music without any headphones it seems like there is still no music being played. Even when I'm typing or when something pops upon the screen there is no sounds and same with the alarm
Stop talking about YOUR PROBLEMS AND SAY THE ANSWER
댓글 7개 더보기
댓글 달기
답변 41개
선택된 답변
The external speaker is contained in an enclosure near the dock. You can try what Andrea suggests, as the left lower part near the home button is over the speaker connection. Otherwise, you'll need to replace the speaker enclosure.
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
I hope you mean the dock-connector right? Since the issue is not related to the dock itself.
Please note that ringtones work fine, only music doesn't.
So bloody stressful mine is doing the exact same thing as yours, I dont know what to do I just want music when getting ready for goodness sake
Mine a iPhone 6 and I can't hear any music on mine does anyone know why I also can't watch any videos is no sound
Mine to, why is it only happening to iphones. Isnt it strange. It cant be a coincidence.
댓글 달기
가장 유용한 답변
Hi,
I had similar problems and what I found is that the bottom charging slot where the USB cable attaches to the iPhone had a buildup of dust and stuff from being in my pocket. All I did was gently scrape this dust out with the edge of a folded piece of paper, and it worked again.
Hope this helps.
Rob
해당 답변은 도움이 되었습니까?
점수 14
댓글 17개:
Yep just cleaned out the USB port with a folded piece of paper and it started workin again
I followed the advise...it worked and then all of a sudden it stopped working again. I don't know what else to do.
oh my gosh thank thank you rob my volume now works! I didn't think it would because I didn't know that the USB port had anything to do with the volume but I threw caution to the wind and put a little a corner of a sticky note inside the USB port cleaned out all the dust and now it works I'm so happy I can now watch Netflix without my volume coming on and off and then stopping completely.
Holy cow!! I could freaking kiss <3 you Rob!! Thank you! My volume is working again....YAY
Hi poeple my volume is not working wht shal I do can some one helps wen I put the volume lound is say it on headphones and is not working
댓글 12개 더보기
댓글 달기
Just toggle the Do Not Disturb Icon. Yeah, i'm a genius. Thankyou. - Jano Pogi
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Wonderful... Working after press Do not disturb button. :) Thank You so much...
This helped me thanks a lot
Brilliant!! You are a genius, I cleaned, maintained and unplugged and earphones numerace times until this nothing worked!! Thank you so much A***
You are really a genius..... It worked just fine. &&^&^$^ apple... Yeeeehaaaaaw
댓글 달기
I had exactly the same proble, tried updating, master reset etc. but still only mananged to get sound through headphones or music music dock. Volume up and down buttons did nothing too. The problem wasn't software related at all but infact a simple fix. The headphone output was dirty and was making the phone think there was still an input there (volume buttons still didn't work though). I'd read that someone fixed this by repeatedly inserting and removing their headphones but I managed to fix it with a high pressure air line at work. Happy happy now!
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I worked for awhile now it stop working someone please help!!!
Followed the advice and back to life again, Thanks :)
댓글 달기
I see this issue a lot, and usually it's tied in with another issue where the volume keys on the side of the iPhone will not adjust the volume from the home screen. The volume icon will show up on the screen when you push the buttons but it won't adjust, but during phone calls or when playing back a voice recording, the volume buttons work fine. This issue also causes music not to play from the speaker. The issue is ALWAYS the dock-connector in my experience. Either clean it or replace it if that doesn't work.
*Note: If you want to test to see if this is the issue, remove the back of the iPhone and while it is still powered on, remove the 2 screws securing the dock connector flex, and unsnap it from motherboard. Now test the volume keys from the home screen. If it works now, you know your issue lies in the dock connector.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Just did that and it 1000% solve my problem!!! Before i thinking of taking my idevice to a repairer buh not anymore!!!! A million thanks
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
a q-tip works great to clean headphone jack . just pull some of the cotton off the q-tip to clean inside of headphone jack
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
My iPhone 4s also only works with earphones, almost can't work if with earphone, then I bought a new earphone from http://www.iboxfix.com/ and replaced it, but it still can't work. Who can help me with this?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It's reli works!!! I just use a cotton bud to clean the headphone jack .. The volume bar working again... I think its some moist inside..Thx so much for the wonderful sharing
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I did the same thing, with a small needle I took out all the rubbish inside the USB connection. Immediately worked out.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Exactly the fix; used a simple keyboard air spray cleaner down the headphone hole and it worked.
Somebody should invent a little plug for that hole, I never use it since i connect to speakers via bluetooth.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
omg thank you guys... this happen to me today my phone was ringing but i couldnt hear when i answered unless i put the phone on speaker , n my music wudnt play either and i use the keyboard air in a can and it totally worked.
댓글 달기
try to do home sharing its working on my device hope its work with you all ....
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Plugged in headphones and heard everything just fine. Unplugged them and now it's working fine. Just something stuck in the jack, I guess. I have an otterbox covering the jack and never use it, so who knows. This thread saved me a trip to the Apple store - thanks!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
this worked! thank you so much
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I tried the air blast - nothing.
And then rubbing some paper across the bottom connector to removed dirt worked!
thanks for the tip
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Thanks, after blowing the air in the headphone doc it worked immediately. Once again thankyou so much
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I am also faced this problem. And it's resolved now thanks a lot..
댓글 달기
Dropped my phone in my coffee..... then no sound, only headphones. let it stand for about 1/2 hour... then took a hairdryer on it's coolest setting for about 5 minutes into the headphone jack. My power button also does not work. Good as almost new!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
A smal cotton buds that can fit into the headphone hole can Also Help Fix the issue
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The diminished cotton swab combined with gently scraping around the charging dock area with a toothpick loosened a thin chunk of dusty dirt. I also blew air into it a couple of times. My sound was up & running & volume buttons work again!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Omg yah just toggle the do not disturb it worked for me fine !!! :D thanks so much @Jano Castillo
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
thank you !!! it was totally the fix!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Nothing works for mine :(
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You need to replace the dock. The phone thinks it is docked all the time hence the inability to change the volume as you'd normally change the volume on the dock itself.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Dock in , dock out.
Dust free totally. Always kept in cover but this volume carry on comes n goes.
Guess I'll just need to update next time with a Samsung :(
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I just had the same exact problem and cleaned the speakers with a q tip and it worked
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I accidentally dropped my phone in a bowl of ramen noodles and I got it out fast and I ca
N only listen to YouTube with headphones and the volume button up and down doesn't work if u press it volume comes up but it won't adjust I have talking tom tht works perfect without heAdphones and alerts but I can't listen to music without headphone
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
And it looks burn a little at the USB port
댓글 달기
my phone is not even a month old! i tried the paper cleaning like you were talking about, plus i tried the air duster. it worked for like 2 seconds and then stopped again! i havent even had this iphone 4s a month yet! help me!
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Alex I would just take into the apple shop as they usual replace if less than a year old. I'd not bother tryin to fix because it could happen again whereas yu might just b given a brand new one instead . X
Have you fixed it yet? i was wondering maybe you fixed it and can help me out cuts it only works for like 2 seconds and it gone pls HELP!!!
댓글 달기
It works i got a tiny peice of long plastic and slowly put it in and wow the amount of dirt i found in both the slot for the charger and the headphone port was incredible.
Thanks for this :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I found out a solution. I took a tiny metal bit and
scraped the headphones til the sound worked
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi, can anyone help. I have an iPhone 4 and all my sounds are working fine when I watch Facebook videos and get a message or anything. My sound is only not working when I try to watch something on the internet? HELP PLEASE!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have an iPhone 4s and the sound only works with earphones and sometimes it doesn't work when I have the ringer on. I need help
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My sound was working fine, no problems with it or anything.
I dropped it while running inside one day when it was raining, and didn't notice it was gone until less than five minutes later. Everything on my phone works, nothing is wrong but the sound.
The ringer works, and alarms and whatever works. When I went into 'Settings', 'Sound', and moved the sound bar, the sound works.
When I play music, it will work anywhere from 1 song to about 5 songs, then it will just.. Stop. The song will go back to 0:00 and play, but no audio. While in 'Music', 'Now Playing' or whatever it's called, there is no sound bar. There's just the go back, pause/play, and skip button.
When at home screen, the buttons don't work unless it's Ringer button, and when I press the buttons the little box shows up, but again no sound bar. When I pull up the tab from bottom screen up, same thing.
I tried the paper, tooth picks, headphones, still doesn't work. It will work after restarting the iPhone, but it will eventually stop. Sometimes I have to restart 2 times within the same minute or two minutes or whatever.
Is there any way I can fix this? If I have to replace the headphone dock, does anyone know how much it will be?
  • Btw I have an iPhone 4s if that matters.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi everyone,
I've tried all these and it hasn't worked it only works with headphones an when I'm being called or alarms I don't know what to do and I turn it up with the buttons and it's just saying ringer with nothing there?? Any ideas
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Mine is like that to just don't know how to fix it!:(
댓글 달기
YIP YIP!
Cleansed the pins at the bottom of the phone like an old NES cassette. I used a sani-cloth wrapped around a paperclip and scrubbed for 20-30 seconds. I had cleased the dock area previously without effect, but cleasing the actual pins worked. The sound came and went once. I recleansed the pins a second time and have had sound for hours now.
Thanks for the suggestions folks.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hey my phone only works when I put the headphones in and it is really bothering me can someone help me!!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I don't know how to do it either you can try cleaning out the usb port or cleaning out the headphone jack.Hope this helpped. HAVE YOU FIXED IT YET WHAT DID U DO?
does not work
댓글 달기
Somebody help me? If i play music and video the speaker doesnt work. But the phone calls and text message alert is working. I already clean the headphone port. Its still doenst work.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Iphone 6
No Sound at all. When turning volume up or down with side buttons it would only say headphone. Took compressed air and blew out the charging slot and headphone jack. Normal sound works again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My iPhone also doesn't sound. Sometimes it rings but sometimes not. What will I do? I already tried all of the suggestions given. Please help me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It mot walking the sons on my iphone 4
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
My iphone 4 sound not working
댓글 달기
Happens with mine but the ringtones and typing sounds don't work and even the sound bar disappears on the white screen that you pull up from the bottom, though ever minute or so everything works but only for about every other 30 seconds.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
iPhone 3,3gs,4,4S Audio & Videos Sound Problem Solutions...
https://www.facebook.com/amimobilepoka/p...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Pim V 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 334,634
