Why is my phone slows?
It runs slow how to fix
좋은 질문 입니까?
Hi @abudi78
Try the following and check if doing any improve performance.
해당 답변은 도움이 되었습니까?
There are a few reasons that a phone can slow down. Attempt a restart of the phone by pressing and holding the power button and the volume button on the side of the Samsung Galaxy A21s until the screen turns off. After turning it back on see if that helps the issue. Otherwise, it could be an issue with how much data is on the devices storage. See if you can unload some data and see if that helps the issue.
해당 답변은 도움이 되었습니까?
Try restarting the phone, and checking your phone's system health (you can do this by opening Settings>Battery and Device Care and performing the necessary actions for each category). This will also help you free up space with the help of the corresponding tab. Additionally you can also check for system updates by opening Settings>Software update>Download and install.
해당 답변은 도움이 되었습니까?
Well I will suggest you to scan your phone of junk file by using a good phone cleaner app and also delete the duplicate photos from you phone because we all have so many photos in are phone now day that also fill are phones memory that also mark are phones slow as well.
해당 답변은 도움이 되었습니까?
24 시간 전: 4
7일 전: 15
30일 전: 66
전체 시간: 2,332
댓글 5개
My phone is very slow
العبادي ابو حامد العبادي 의
My phone is not working fastlu
=== Update (08/05/23) ===
It runs slow how to fix it
Uzumaki Naruto 의
@uzumakinar10212
Did you try what was suggested in the Most Helpful Answer below?
If you don't try things already suggested here and then reply if it worked or not then there may be other things that you can try but do them first!
jayeff 의
My phone slow idont khow
Mahendr 의
Tower slow problem could not connect
Bharath Ammu 의
