주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ryobi P214는 18V 리튬 이온 배터리로 작동하는 무선 해머 드릴입니다. 1/2인치 척, 최대 600 in-lbs 토크, 0~400/0~1600 RPM 속도를 갖추고 있습니다. 이 페이지에서는 석재 드릴링을 위한 해머 기능, 24단계 클러치 설정, 배터리 호환성을 위한 One+ 시스템을 포함하는 P214에 대한 상세 정보와 수리 안내서를 제공합니다.
Can't remove chuck from drill
이미지
I have the ryobi p214 cordless drill and no matter what I cant remove the chuck. I took the screw out from inside the jaws and I put an allen wrench in and held it with the jaws. I managed to turn the chuck counter clockwise but it just barely spins without loosening at all. How can I get the chuck off?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 5개
@archiep once you got the allen wrench locked, you placed your drill in REVERSE (lowest torques setting)and you do have a full battery? Now pull the trigger. Careful, It'll kick a bit and you got to hang on to it and watch your wrist.
I did this, but the drill started smoking and it also kept auto braking unfortunately.
I have the same problem? I cant tighten the chuck enough to stop the drill bit just spinning in the chuck , so , I want to fit a new one but cant remove the old one? Cant see any screw / bolt up inside the chuck at all? Hopeless system?
Had the same problem so dismantled the drill down to the point where I had just the shaft with 2 flats on the end, clamped it in the vice , 10mm hex key in the chuck and heated the hell out of the old chuck, it let go with a bang and the thread is not a 1/2" 20 thread as mentioned, still to indentify, be careful during disassembly as a lot of small gears and parts, photograph each stage.
Also good to note that the screw is a reverse thread
댓글 달기
답변 1개
가장 유용한 답변
A few things that may help; first instructions on how to deal with the situation. here next a reminder that this has a 3 year warranty in case that still applies and your owner's manual here in case you need it, which gives instructions on pursuing your warranty or service. Last; schematics and parts are available here
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you for the useful content, however, the article link is doing something different than what I'm trying to do. I don't have a bit stuck in the chuck, I'm trying to remove the chuck from the body of the drill. I used the schematic you shared to illustrate my situation.
OK, well, in the very unlikely event that @oldturkey03 's advice didn't do it for you, (he's a pretty darn sharp tack) I did find an answer to that too...somewhere but should have read your question more carefully.
댓글 달기
답변을 추가하세요
Archiep 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 54
전체 시간: 2,707
