5650C low air output - is there a filter inside machine to clean?
compressor is not putting out enough air to make tobi or saline solution effective
Can compressor be taken apart ? Cleaned? filter changed at home?
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
Here's the service manual that may help.
The Maintenance section on p.2 describes how to access the air filter (Item #14 see p.3).
Replacement filters are available online. Just search online for the part number(s) i.e. 5650D-602 (5/pkg) or 5650D-601 (25/pkg) to get results for suppliers that suit you best.
If the filter is OK then check the other possible causes for reduced air output as per the troubleshooting guide on p.4.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 114
