주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Why is my phone shutting off randomly?
I have a Samsung Galaxy A40 which keeps shutting down randomly, for some minutes after it has shut off it doesnt want to turn back on and if i try to plug it in a charger it just bootloops. I cant also take a picture with flash or it will shut off, what can it be the issue?
Update (05/29/2022)
also its not a software issue cuz i factory resseted it
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
The battery is going out. Here's a guide to replace it:
Samsung Galaxy A40 배터리 교체
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
thanks i guess
댓글 달기
There are other possibilities, @guardian10 is probably correct, but it could be due to for example water damage or a recently added app. If the phone works okay while plugged in to power with the original cable and power supply, but not when unplugged. (Assuming no damage). He is right. If it makes no differences, restart in safe mode to disable 3rd party apps, if it works fine figure out which were installed bout the time the symptoms began. See if uninstalling it fixes things... if no joy a new battery may cure it. I'd recheck the charger and cable first, though.
이 답변이 도움이 되었나요?
점수 1
댓글 5개:
You re right, that factory reset ruled out software issues, I was thinking soft reset!
I factory resseted the phone 3 times but didnt help
one time it shut off during the factory reset
the issues dissapear when plugged in
Then that gives you the answer, if it works fine while plugged in: it is time for a new battery. Follow the guide @guardian10 posted above or find a local shop or a mail-in repair service to do it for you.
댓글 달기
답변을 추가하세요
usdfudihufd 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 25
전체 시간: 1,679
