주요 콘텐츠로 건너뛰기
Updated version of the Kindle Fire 7" tablet by Amazon with 1280x800 HD display. Released September 2012. Repairing this device is straightforward.
100 질문 전체 보기
How can I get a wire head phone jack out of my fire tablet
I had a pair of wired headphones and I had the jack suck an do forgot so I decided that my new head phones can go in but when I tried it pushed the jack in further and I can not find a place to get it out
Update (05/31/2022)
Also now I cannot hear anything
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi,
Try opening the tablet and check if the broken headphone plug tip can be pushed back out of the jack at all.
If not or doing this damages the jack, you may have to replace the jack.
Here's the ifixit Kindle Fire HD Headphone Jack Replacement guide that may help.
As they are not all the same for the different Fire HD models, to find suppliers of the correct replacement part, look for the model number of your tablet (usually found on the back cover) and search online for Kindle Fire HD (insert model number) headphone jack
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I had a few ideas to suggest, but then I ran across this article that covers them all, and then some.
How to Remove a Broken Headphone Jack - Headphonesty
Easiest and most straight-forward is to use the ink barrel from a ball-point pen, it should fit over the broken plug and pull it back out. Worst case there are tools available made specifically for that purpose, and iFixIt even sells them here.
GripStick Headphone Plug Extraction Tool - iFixit Store
GripStick Headphone Plug Extraction Tool 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
SCARLETT BORN 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 18
7일 전: 80
30일 전: 328
전체 시간: 2,624
