should I clean my fans manually or replace them?
my fans are dusty and i am wondering if i should clean them myself or just replace them entirely?
좋은 질문 입니까?
좋은 질문 입니까?
Cleaning is quite easy! Get a small soft pain brush and a can of can'ed air so you can blow out the dust & debris.
I would follow these two guides as its better if you remove them:
Carefully scrub the blades as well as the heatsink fin areas. I blow the air outward across the fins and a few short blasts on the fans. You don't want to spin them up, I often carefully wedge a toothpick to hold the blades from moving. Don't for get the give the logic board a quick wipe as well with the brush and then blow off what you've loosened up.
안내서
난이도:
운영
45 minutes
안내서
난이도:
운영
20 minutes - 1 hour
해당 답변은 도움이 되었습니까?
Thanks for the help
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 106
