주요 콘텐츠로 건너뛰기
Repair for LED, incandescent, and other handheld electric light sources.
Where can I get a new bulb
i have a ledlenser f1 torch the bulb on it has been broken where can i get a new one?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Did you try contacting the company?
If you can take the bulb out and take a couple of pics so we can get an idea on its size and base (hint put a ruler in the picture) 기존 질문에 이미지 추가하기
댓글 달기
답변 1개
가장 유용한 답변
Laurence Ockerse this "flashlight" doesn't use bulbs. It use an LED as a lightsource. This in general are not replaceable but can be repaired. First off there should be a 5 year warranty on this so check to see if you are still covered. If not then you want to tackle the front ring. Use this manual LED Lenser F1 and check around page 16. That should get you to the LED. Post some really good pictures about what you see and post those with your QUESTION. That way we can see what you see and hopefully guide you further through this repair. 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Laurence Ockerse 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 158
