Loud groaning sound when draining
Noise is most prominent and consistent during the tub clean
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
Have you checked that the drain pump filter is clean etc and not that there is a build up of lint etc causing the drain pump to labour when the machine is draining?
Here's an image from the user manual to show where it is located.
(click on image to enlarge)
If it appears to be OK, here's the Wm3180 Service Manual that may help. Go to p.18 to find out how to get into the Load Test Mode to test the drain pump to see if it's what's making the noise.
On p.37 it shows how to test the drain pump with an Ohmmeter to make sure that it is electrically OK and its location is shown on p.51 - see part #K340.
If the pump seems faulty search online for 4681EA2001T to get results for parts suppliers that suit you best.
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 11
30일 전: 57
전체 시간: 2,031
