주요 콘텐츠로 건너뛰기
Apple이 2019년 3월에 출시한 새로운 iPad Air 태블릿, A12 Bionic 프로세서와 10.5" 스크린을 자랑합니다.
Broken Home Button Cable Lock
Hey Guys,
I have run into a situation with a customer's iPad Air 3 that came in for a screen replacement. The first screen I ordered came with the digitizer broken, returned and had another shipped out same day. The new screen was perfect and worked fine.
My issue is that when I migrated the home button over to the new screen and connected the small cable into the connector but when I went to push the lock down, it actually snapped off immediately. The connector doesn't look damaged but the lock is broken off and cannot just put it back on.
Is there any way to get the home button recognized with the current connector? or should I just need to buy a new screen again? lol
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
These sometimes come off but they are easy to put back in if you have some magnification. If the lock part is broken you should be able to source another one but to me it looks fine and just needs to be reinstalled onto the connector. The home button should still function but as it is a customer’s device I wouldn’t leave it off.
@hellomacos Ended up putting a couple pieces of clear masking tape on the other side of the contacts and put it into the connector and put a few pieces of tape on both the cable and the connector to hold it in place. This took Many tries to get right but it finally worked. The lock was physically broken and I could not get it to pop back into the connector.
Thank you for the help!
Your welcome!
Glad it worked out for you!
If you need any other help give me or anyone else here a shout!
댓글 달기
답변 1개
가장 유용한 답변
As Chris has said before me you can reattach it with magnification
I think you might get away with putting a thin piece of paper or plastic the same thinness and width on top of the cable to help force it down better
I would recommend the first one though because the second option is really a last resort!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Mitigate 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 6
지난 30일: 13
전체 시간: 185
