Screen only responsive to S-pen on Samsung Note 20 Ultra
The top half will not respond to touch except its just fine when I use the S-pen. Unfortunately cant find the S-pen. (arggh!) Whats wrong, what can be done?
좋은 질문입니까?
좋은 질문입니까?
On phone screen enter the following:
*#2663#
Then on next screen run TSP Firmware Update.
After success is reported, select < (back) and see if it is fixed.
Other things to try:
Try a simple reboot, that fixes many problems.
Next: Try a safe mode reboot:
Press and hold the Power Button, Menu will open, Press and hold Power off for several seconds: select “Reboot to safe mode” and press Press Ok. If touch is working ok you have a software issue. Uninstall any recently added 3rd party apps. Reinstall them one by one from the play store to find (or hopefully fix) the culprit.
Wipe the cache partition:
Turn phone off.
Press and hold the volume up and power buttons simultaneously
When Android logo appears, release the buttons.
Wait for Installing system update message 30 to 60 seconds.
In system recovery menu options, press the volume down button to select wipe cache partition, Press power button to wipe cache partition, Press volume down button to select yes., Press power button to apply yes,. Press power button to restart when Reboot system now is displayed
Adjust screen sensitivity: settings, display, touch sensitivity, on
Clean the screen
Remove the screen protector
You can also test your display with apps available on the Play Store.
Next thing to try is a factory reset:
Note: all your data will be erased so before doing this back up your files. Be sure you know your account info and password! Or you will be locked out!
Settings, system, Advanced, Reset Option's, Erase all data. (factory reset) select “Reset Phone.”
이 답변이 도움이 되었나요?
Thank you so much. I love it when someone knows and shares multiple fix possibilities. Most people I know say replace it or it cant be done.
On another note.. Have you ever heard of the problem with Note 8 where if you let the battery drain to empty sometimes it will never charge again? That happened to me for no apparent reason and Samsung just said sorry, it happens. I figured if there was a possible fix you would be the one to ask.
Which solution worked for your touch screen issue?
I'm facing same issue in note 10 lite. Sometimes touch work with finger (no back, recent app and home at all) but s pen is working. I tried safe mode but no change. Is there possibility that issue related to charging port? ( I saw a video).
Please help.
@tanmayshar66572 No, the charging port doesn't have anything to do with whether the touch screen works or not; that will strictly be a function of the screen itself. Try @jayeff's answer below, and if that doesn't help you're most likely looking at having to replace the screen to fix the problem.
i started facing this issue yesterday after i updated to the latest software update on my note 10 lite. i have tried all of the above stated solutions by you, even hard reset my phone, but the issue still persists. Is there anything else I can do before i approach the samsung support?
Hi @aurorableme ,
The s-pen works differently to the touch function.
It could be a faulty (loose) touch cable connection or simply a faulty touch screen (digitizer)
Here's the ifixit Samsung Galaxy Note20 Ultra 스크린 교체 guide that will help.
At Step.17 the touch cable connection is shown.
If the connection seems OK you may have to replace the display. Looking online replacement displays aren't cheap ;-(
이 답변이 도움이 되었나요?
Since this has already been answered, I don't feel as bad "answering" just to say mines doing the same thing.
I'm nearly certain it was caused by me dropping it, though.
I've tried updating the firmware, but that didn't work.
I'm really curious to know what the specifics are for how it's able to work with pen but not touch!?
If anyone knows, please do share!
이 답변이 도움이 되었나요?
Hi Heather,
On a phone the touch screen, or digitizer as it's more properly called, consists of a thin sheet of glass or plastic with invisible electronic circuits printed on it, that's bonded to the front glass. On Samsung phones that support an S Pen, there's not one, but two digitizers behind the glass. One of them is sensitive to the S Pen while the other is sensitive to your finger(s).
Since they are two separate devices, it's entirely possible for one of them to fail while the other continues to work; thus you can have a phone that responds to fingers but not the S Pen, or one that can see your S Pen but not your finger.
Of course, since they're both bonded to the glass along with the LCD or OLED display, the only fix for a failed digitizer is to replace the screen assembly, giving you a new display and new digitizers for the S Pen and your finger.
I was so glad to learn the screen could work with pen after top of my screen stopped responding to touch!! I was able to use the phone, (albeit quite annoyingly), after dropping it & breaking the digitizer.
In case anyone ends up in this position in the future...I also installed an app to allow screen rotation on any app. That, along with using S pen, gave me a couple options to keep using my phone, even with a broken screen.
My phone fell outta the car door, not long ago.(Whoops!)🫣 Screen went totally black after that.
I installed a replacement screen yesterday. New screen doesn't respond to touch, only s pen.😫
I've read everything online on the subject. It appears one ribbon cable connects the LCD to motherboard. Since I can see the screen, I assume it's connected.
*#2665# update fails. WACOM update works, but it's for s pen function. I read downgrading firmware might be solution. Is that true? Or did I just get a dud screen?! How 2 downgrade screen FW?
지난 24시간: 1
지난 7일: 26
지난 30일: 151
전체 시간: 30,251
