주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad L460은 2016년 1월에 출시된 14인치 비즈니스용 노트북입니다. 내구성이 뛰어난 구조와 무광 블랙 디자인이 특징이며, 키보드 중앙에는 붉은색 트랙포인트가 있습니다. 무게는 약 4.2 lbs(1.9 kg)이며, 인텔 6세대 코어 프로세서를 탑재하고 신뢰성을 갖춘 제품입니다. 비즈니스 및 교육용으로 적합합니다.
Problem with screen or motherboad?
My lenovo T460 has no 3.3V and no other voltages on screen controller board (CON) except the 20V on the connector and in a big coil. Also no backlight and no picture. Is it possible to have fry anything in main motherboad ? (My hdmi output working normally with my external monitor).
Initially I changed the screen cable, because my screen was changing colors and making vertical shades with freezing picture, especially when the lid was moving.
Initially the problem seems to had be solved ,but after 5 min the problems return, so I opened the screen and begun probing on the CON for voltages and any defect cups and at that time the backlight and the picture was on, with the defects showing..
Now it's only a black screen.(with working hdmi output to TV)
The question is how do I know that I haven't done anything wrong with the motherboard, while I was probing the screen con board ? The 3.3V and other voltages are coming from the motherboard though the screen cable or from the lcd controller board?
Where could I have to start searching ?
I Appreciate your time
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
Mine has no display but shows charging light and power light
의 공유
댓글 달기
답변 1개
선택된 해법
Hi @metachaos
Couldn't find a schematic for a T460 but found one for a T460s (Compal NM-A581 motherboard) which shows that the backlight power is supplied via fuse F6 on the motherboard and goes to pins 27 & 28 on the LCD connector.
If the fuse is blown it is a 3A_32V_ERBRD3R00X.
If there is no power on either side of the fuse, the power comes from Q1 (TPCF8002_2-3U1A)
If there is power on the pins then then backlight is turned on and off in the screen by a backlight enable signal sent on pin 18.
Here's the schematics that may help you further, (scroll down to the download link). Go to p.38 to see the pinout for the LCD cable connector.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Lord Chaos 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 28
전체 시간: 1,171
