주요 콘텐츠로 건너뛰기
A2115 / 2019 / 프로세서 3.0GHz 6코어 i5부터 최대 3.6GHz 8코어 i9까지. 2019년 3월 19일 출시.
131 질문 전체 보기
Weird psychedelic patterns appearing.
My Mac has decided to add weird, entirely random, colourful psychedelic patches into my black and white photographs. This is extremely annoying.
Does anyone know what might be causing this please?
Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Can you post a few pics so we can see it 기존 질문에 이미지 추가하기
Thanks. I've now done this.
댓글 달기
답변 1개
가장 유용한 답변
Not good ;-{
Did you drop or bang your system or at some point remove the display off to get inside?
This looks like T-CON board issue within the display assembly. To be sure plug in an external monitor to the Thunderbolt ports to see if the problem is visible within it if not then the internal display will need to be replaced.
해당 답변은 도움이 되었습니까?
점수 1
댓글 6개:
Thank you. I will try to do as you suggest.
@danj mightn't it be file corruption? Looks like what you can get with cross-linked files.
@uchetil - If we read the OP's problem we see "colourful psychedelic patches into my black and white photographs." So more than one photo is effected.
Yes, it's possible the issue is within the file (corruption).
But, if it is happening across many photo files its more likely the image is requesting a higher scan rate (deeper pixel depth) which means either the displays T-CON scan frequency is being pushed to the higher from the default the finder uses or the GPU's Video RAM is messed up.
It's not happening all the time but it does effect colour photographs too. I'm not a very techie bloke and if it's anything more difficult than moderately easy to fix, I may have to reluctantly scrap it a buy a new computer.
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
drkrdgrs 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 78
