주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo에서 제조한 ChromeOS 기반 노트북입니다. 11.6인치 디스플레이, Intel Celeron 프로세서, 4GB RAM 및 32GB 내장 스토리지(eMMC)를 탑재하고 있습니다.
Won't power on
I do chromebook repairs for a school district and I have come across a couple hundred 100es that have a charge light, are fully charged (left on charger for 1 day or more), but don't seem to turn on. I've verified that the battery and screen/topcase are working by testing them on other chromebooks. I've also plugged in an external display and the cbs are not sending any display signal. Seems to be any issue with the motherboard perhaps?
I've tried these troubleshooting steps (aside from verifying the physical components as noted above)
-forcing a powerwash
-draining flea power
-unplugging all connections from motherboard and reseating them
-toggling "shipping mode" on the batteries
Sorta at a loss. Anyone else experience this issue or have a fix ?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
I would check the battery’s with a multi-metre to make sure they are charging
If they are t you will have hook them up to a bench power supply and charge them at a low power going into them as we won’t want to damage them do we:-)
의 공유
댓글 달기
답변 2개
The Lenovo 100e Chromebooks have a problem with ribbon cable flaps not staying in place. Open the bottom of the unit and check the flaps on the ribbon cables of the power board. one will probably be up or not down tight. we place a small piece of electrical tape on them to hold the down.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
이미지
please help me fix it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Caitlin Wolf 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 45
전체 시간: 1,133
