주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년에 출시된 Nikon D3300에 대한 수리, 분해 및 문제해결 정보입니다. Nikon D3300은 입문자용 DSLR 카메라입니다.
Spots On Camera's After Image
Every time I take a photo of a bright surface (usually the sky), dots appear on the after image. There are none when I'm looking through the viewfinder. I thought it might have been the lens, but I tried it with multiple ones. The mirrors in the DSLR don't appear scratched and there's really no visible dust or anything.
My family has had the camera for several years, and this only started about a month ago. It didn't interfere with the quality at first, but now there's more spots and it really bugs me.
Has this happened to anyone else? Is it fixable? If so, does it need professionally repaired?
Thanks for any help.
Examples:
이미지
이미지
이미지
UPDATE: After some more research, it seems like it's dust on the sensor. Best way to clean that?
FINAL UPDATE: It’s clean! After watching some videos, I figured out how to do it on my own. I had previously blown on the mirrors, but apparently I missed a step. To anyone who has this problem, make sure you go to settings and lock the mirror. The one hidden was the issue. I had a kit, but those nose blowers (whatever they’re called) probably work well too.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Check digital camera forums for help. Dustbuster used lightly may blow off dust buildup. A very soft camel hair brush used carefully may help remove clinging dust.
의
Hi Maggie,
Good one! It would be helpful for others if you posted your solution "Final Update" as an "Answer" - cut an paste it into "Answer this question".
의
댓글 달기
답변 1개
선택된 해법
Copy of update since it’s also a solution:
…After watching some videos, I figured out how to do it on my own. I had previously blown on the mirrors, but apparently I missed a step. To anyone who has this problem, make sure you go to settings and lock the mirror. The one hidden was the issue. I had a kit, but those nose blowers (whatever they’re called) probably work well too.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Maggie Kudrick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 19
지난 30일: 40
전체 시간: 396
