Radio shack MD-1160 won’t turn on
My keyboard has no power when plugged in to the dc plug. I have taken the unit apart and have found nothing unusual on the circuit boards other then blackened grease where the on off switch runs. Any suggestions?
좋은 질문 입니까?
댓글 6개
Can you take a picture of the circuit board(s) and upload it here? 기존 질문에 이미지 추가하기
Andrew S 의
Hi @suzang,
Have you checked that the AC/DC adapter power supply that plugs into the keyboard is working OK i.e. that there is 9V DC on the plug at the end of the cable?
If you can't test if the 9V DC output adapter is working, then try inserting 6 x "D" size dry cell batteries ( 6 x 1.5V D cell batteries = 9V DC) in the keyboard's battery compartment and check if it turns on.
Make sure that the DC plug adapter is unplugged from the keyboard if you try this as plugging in the adapter disconnects the battery's power supply to the keyboard
jayeff 의
I have finally put batteries in and it works!🤣. So I guess now I will need to take pics of the two Circuit boards so y’all can see if I’m missing something. I will also be purchasing a new 9v plug for the keyboard.
SuzanGeorges 의
@suzang
Here’s how to add photos!
기존 질문에 이미지 추가하기
HelloMacOS 의
@suzang
Have you tried a different, known working compatible 9V DC power adapter to see if that worked, you didn't say?
jayeff 의
댓글 1개 더보기
