주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for top and front loading Whirlpool brand washers.
Top load washer stuck locked
Having a lot of problems recently with it never finishing, and now stuck locked. Have recalibrated a dozen times. Usually just stops with wash light on with no water visible in it. Wondering if maybe drain pump clogged since it sees a lot of dog hair.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
Hi @noj111,
What is the model number of the washer?
WTW4815EW1 - Fixed the lock issue. Tried unplugging for an hour and still had problem, locked and could not cancel. Put back into manual diagnostic, then was able to unlock. Still fails constantly with wash light on, with clothes wet (not spun) and no water in it. I have 6 long hair dogs and wash their blankets frequently. Wondering if evacuation pump is clogged.
Someone replied, but do not see post. Ran automatic diagnostic and comes back to Done. Does it return fault code or error codes?? If error code could be basket speed, no fill/slow fill, or long drain or a few other things. Totally confused if they are error or fault codes. Figures I finally need glasses, and hard to read microscopic print in manual. How do I get fault codes?
Figured out the code issue. Once in diagnostic mode, turn knob till done light on, press start, all lights flash, turn knob once to see last error, first flash is fault, second flash is error.
댓글 달기
답변 1개
가장 유용한 답변
Hi @noj111
I don't know what a blinking wash light only means so try running the automatic test mode diagnostics as per p.4 (and p.2 Activating the service diagnostic test modes) in the tech sheet and check what error codes if any are shown.
Not spinning might be more the problem than the drain pump being clogged because you said that the clothes are wet, not that there's still water in the tub.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
@noj111
There is a magnifying option when viewing the tech sheet, just click on link above and then when it opens click on the magnifying glass icon with the + symbol in it a few times to enlarge to suit. Top left of document header. ;-)
What code are you getting?
Basket speed fault. Tried to look at bottom but tight in laundry room. Will work on it tomorrow. Wondering if belt issue. Washer came with house so know idea how old. I had the physical manual. Should look it up online for easier reading.
@noj111
There is a download link in the tech sheet I posted (click on link in answer above to open tech sheet manual) if you want to download and print out a hard copy
댓글 달기
답변을 추가하세요
Jon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 17
전체 시간: 1,476
